1. BladeForums has ZERO TOLERANCE for extremism or calls of violence. We request your assistance dealing with this as we do not want to see the site shut down due to violent threats. Please see this thread here in Tech Support: https://www.bladeforums.com/threads/bladeforums-has-a-zero-tolerance-policy-towards-threats-of-violence-extremism-be-warned.1769537/
ANYONE KNOW WHAT IS A DECENT KNIFE SHARPNER?
Discussion in 'Buck Knives' started by JOE NOWICKI, Jun 3, 2020.
  1. JOE NOWICKI
    JOE NOWICKI
    318
    Dec 19, 2018
    I have been looking for a decent knife sharpner. Any Sugestions?
  2. dpsk
    dpsk
    141
    Nov 7, 2019
    It's not meant for reprofiling or for heavily used/damaged blades, but I like the "Work Sharp Guided Field Sharpener" for tune ups. Higher end sharpeners are way beyond my skill set.
  3. Smitty0315
    Smitty0315
    40
    May 21, 2019
    I use the Ken Onion Worksharp. I originally was using the guides but prefer a little more free handed now.
    colin.p likes this.
  4. jbmonkey
    jbmonkey Platinum Member Platinum Member
    Jun 9, 2011
    sharpmaker works great for touchups. reprofiling I use a wicked edge or just my diamond bench stones and freehand. i used to use a belt sander, but now just use stones or sharpmaker.
    Jeff of the North likes this.
  5. Jeff of the North
    Jeff of the North Gold Member Gold Member Basic Member
    262
    Feb 22, 2020
    I have a Lansky Controlled-Angle system with a ton of grit options that I'm very satisfied with.
    EricRedAxe likes this.
  6. afishhunter
    afishhunter Basic Member Basic Member
    Oct 21, 2014
    A steady hand and a Smith's or Lansky tri-stone with a man-made "coarse" plus medium and hard Arkansas stones?
    jbmonkey likes this.
  7. PirateSeulb
    PirateSeulb
    Jun 6, 2017
    Are you looking for a guided sharpener? What kind of budget are we considering? What type(s) of steel are you sharpening?
    I have and use a KMT Deluxe kit and it works great for all my needs so far.
    I liked the idea of the Ken Onion Worksharp but I feared a motorized system, particularly with me, would do more damage than good but definitely a tempting system.
  8. BP_
    BP_ Gold Member Gold Member
    Aug 26, 2015
    I use my Work Sharp KO and my Sharpmaker, and a strop. They are both easy to use, which was important to me when I first got started :thumbsup:
  9. jbmonkey
    Jun 9, 2011
    easiest is a belt sharpener. factory even uses one. just be careful knocked off or rounded tips if not taken off the belt at the right time, and too much removal and convex edges which isnt a bad thing if it isnt over done.
    I still use mine for my user machetes, much faster than a file or stones.
    SOLEIL and Jeff of the North like this.
  10. Wolfjohn
    Wolfjohn
    472
    May 16, 2002
    Believe it or not, that little pocket/keychain Mini Crock Stick puts an incredible edge on a blade. Awesome for $5
    bucksway and jbmonkey like this.
  11. guy g
    guy g Gold Member Gold Member
    Oct 22, 2000
    Sharpmaker
    Badhammer and jbmonkey like this.
  12. SOLEIL
    SOLEIL Gold Member Gold Member
    Mar 20, 2006
    All in all, the best sharpeners are the ones that each individual excels at. I use belts, diamond and ceramic rods/ovals. Stopped using stones and guided systems long past. There are 100 ways to sharpen and they all work given the skill of the user. You may go through a number of different ones until you find what's best for you. The quest for sharpeners can get as expensive or as cheap as the knives you're sharpening. The grail quest for the KNIFE and the SHARPENER can end up at an equal cost.
    954Ink, mbkr, JSutter and 5 others like this.
  13. GPyro
    GPyro Gold Member Gold Member
    Apr 18, 2019
    Just make sure that whatever you chose goes to the angle that Buck sharpens to.
    Some don't.
  14. jbmonkey
    Jun 9, 2011
    good point. need +-30 inclusive typically. course free hand benchstones allows for that.:)
  15. Hickory n steel
    Hickory n steel Gold Member Gold Member
    Feb 11, 2016
    I do all my sharpening by hand.
    It's not too hard to follow the factory bevel and keep a good edge on all my old school blade steels such as 420hc from Buck.
  16. sassafrassdogs
    sassafrassdogs Gold Member Gold Member
    Jul 21, 2016
    I send mine to Buck for the SPA service, it's only $6.95 per blade and it's done right.... If it's not a Buck I use a tri-stone...
    bucklife301 and jbmonkey like this.
  17. Ernie1980
    Ernie1980 Gold Member Gold Member
    Apr 19, 2012
    I have tried lots of different ways over the years, from guided systems to water stones. Now, I most often use the Ken Onion Worksharp. It gives great results quickly, and when used on the lowest speed you won’t do much damage even while learning.
  18. MT_Pokt
    MT_Pokt
    Jul 21, 2014
    I use the Sharpmaker unless I need to do some serious profiling then I use my Norton IM313.
    David Martin, Badhammer and jbmonkey like this.
  19. bucklife301
    bucklife301 Gold Member Gold Member
    Nov 3, 2018
    I use the ken onion work sharp for stuff that’s usually never been sharpened or has bad edge damage or broken tip and needs reprofiled , I think I have become a pro with the work sharp, But I just use a ceramic rod on my new stuff when it gets a little dull
  20. BuckShack
    BuckShack Gold Member Gold Member
    Jul 19, 2015
    I use a brass EZE Lap Diamond "M" mainly because it looks cool and it's easy to carry. It works. But, I use a ceramic rod mostly and touch up the edge frequently (after use) and test on paper as I go.
    Bloefield likes this.
Share This Page
