Axe info
Discussion in 'Axe, Tomahawk, & Hatchet Forum' started by devilpig, Mar 24, 2010.
  1. Yankee Josh
    Yankee Josh Gold Member Gold Member
    Mar 31, 2018
    What is your budget? $20-$30 should suffice. I would suggest an older True Temper, Plumb, Collins etc.
    There are some good users you can find on auction sites. Folks are usually more interested in a stamp or one in perfect shape so you should be able to find a user pretty easily. If you browse through the thread "what did you rehang today" you should get some good ideas of what to look for. Good luck!
    A17 likes this.
  2. Iron Forge Knives
    Iron Forge Knives
    1
    Dec 3, 2019
    Page 9 of this post theirs a Keesteel washboard axe (red groves) does any one know who has it... I sold that axe 3 years a go and would love to get it back
  3. jake pogg
    jake pogg
    Dec 20, 2015
    This is a cool thread...(somehow in spite of it being pinned it's the first i see it...:(...)
    Lots of valuable info...albeit any organisation is lacking,so would be very difficult to reference any of materials here,alas...
    Divorced from my forge i'm desperately seeking solace in axe theory...(never a particularly satisfying deal,but marginally better than nuffink:(...)
    And have come across the following research in archaeology of axes,and decided to deposit it here,for s**s&giggles...
    Here's the paper itself,and lower down i'll talk briefly about what it is and whence et c.It's reasonably fresh,as these things go,early 2000-teens it seems.
    https://cyberleninka.ru/article/n/klassifikatsiya-srednevekovyh-toporov-permskogo-preduralya/viewer
    This paper is about an archaeological inquiry into axes made and used by Mari people(a rather disappointing overview:https://en.wikipedia.org/wiki/Mari_people).
    They are a Finno-Ugric group of folks that (probably)originated in Western Siberia,but at some point early in first millenium A.D. have crossed the Ural mountain range over to the European side of it(poor suckers...ended up square in Mordor..)...Afterwards,they seemed to've spread further North and Northeast,becoming ass'd tribes along the Northern coast of Mordor and Westward,such as Karelia and Finland(also a smaller group seemed to have headed to Hungary).
    There they settled,and live there to this day;they Did try to get rid of "russians"(for lack of better term;as in whatever ruffianly tribes were filed under that ambiguous adjective during those centuries),but alas unsuccessfully,their three known major attempts failed(one by a Very narrow margin).
    What's germane here,however,is that they have brought with them(from Siberia or wheresover) sufficient ad skills.Enough to make iron via reduction process,as well as to know the ABC's of Iron-Carbon reaction,an ability to produce either and most probably the HT of carbon steel as well.
    All of those skills allowed them to make axes of many shapes and sizes,some startlingly "modern"-looking(the correction must be made for the incurable Half-Assness of USSR/RF science...some artefacts could be from elsewhere...Anywhere...(and it's not the fault of scientists themselves for the most part but the Mordor-state running the biz).
    An interesting rabbit-trail may be that the so-called "ost-vikings",those that went North and East and then South overland to Caspian and Black seas have done this by taking the very rivers that were inhabited then by assorted Mari tribes.
    So if there was an exchange of ideas on tool-making between those folks and what may've been the result is still a very much open question.
    In any case,check out those neat axes...Both slit&drifted and welded composites are represented,many eye shapes,lugs,et c.,et c...
    A17 likes this.
  4. jonshonda
    jonshonda
    9
    Dec 16, 2019
    Looking at this double bit cruiser axe but cannot find any info about the makers Mark. Any thoughts?
    [​IMG]received_452307059018261 by Jon S, on Flickr
    Miller '72 likes this.
  5. George Lottermoser
    George Lottermoser
    1
    Feb 5, 2020
    [​IMG]
    While trying to ID granddad's right hand, single bevel carpenter's broad axe I discovered it came from The Pritzlaff Hardware company, founded in 1850 by John C. Pritzlaff; largest in Milwaukee, Wisconsin. Eventually, largest in "Northwest". Closed 1958. EVERKEEN CAST STEEL
    dn4911, Miller '72 and Meek1 like this.
  6. NoloYas
    NoloYas
    5
    Mar 29, 2020
    This probably isn’t a very relevant question but I happened to see a kelly registered axe with the words “pink panther” stamped in the back. It was a jersey pattern and still had some pink paint on the axe... is this someone making a forgery or was this an actual axe? Any info would be great! Thanks!
  7. Ryan Glen
    Ryan Glen
    3
    Apr 28, 2020
    This came as part of a job lot.
    3.3/3.4lb scotch pattern . Sorby is all I can make out.
    Can't find much on it. Plan as a project was to grind the rolls, weld the cracks, finish and use it. Is rare/any value? Only found 1 pic online that looked similar listed as a 053. If it is 100yrs old+ it might dersrve better than what i have planned for it[​IMG]http://imgur.com/gallery/rstMsrd
  8. crbnSteeladdict
    crbnSteeladdict
    Jul 31, 2017
    [​IMG]
    I was wrong about I&H Sorby. Your axe maker's mark looks more like
    Turner, Naylor & CO's I Sorby
    Mr Punch
    [​IMG]
    https://www.worthpoint.com/worthopedia/vintage-sorby-viking-ship-builders-616975315
    [​IMG]
    https://www.worthpoint.com/worthopedia/sorby-punch-brand-tools-1938-hardback-1772249945
  9. Ryan Glen
    Ryan Glen
    3
    Apr 28, 2020
    Fantastic information. Thank you. I might have to retire this axe. Cutting and welding the hairline cracks seems the wrong thing to do. Might just leave it as is
  10. Ryan Glen
    Ryan Glen
    3
    Apr 28, 2020
    After closer inspection in daylight it looks as if whoever stamped the axe had two attempts. The I.Sorby part has two I's the first followed by the jagged border edge, there are some traces of the letter overlayas ghost prints in the steel. The first "I" also sits higher.
    After doing a bit of digging I came across this thread https://www.ukworkshop.co.uk/forums/mr-punch-first-appearance-i-sorby-t82871.html
    I'm still struggling to date and value this axe as the punch trademark was registered in 1859. Examples on tools appear from 1876 from what I've read and continue till mid century.
    The small cracks and the stamp fudge may detract from value?
    If the head doesn't have much value/rarity I find myself tempted again to have it repaired and use it as the cutting edge hasn't seen much action.
    The I.Sorby scotch axe pattern doesn't seem to be that common or mabey there just isn't a lot online? I'm on the fence again!
  11. I need help
    I need help
    2
    Jul 19, 2020
    This is my first time on the forum. Im looking for a new offset handle for my grandfathers broad axe. I'm in Ontario. Thanks
  12. A17
    A17
    Jan 9, 2018
    Try Beavertooth handles.com.
  13. Jackie Dengler
    Jackie Dengler
    21
    Nov 6, 2020
    He
    lp me buy the best axe Viking style read my msg on axe tomohawk hatchet by Jackie Dengler please
  14. Jackie Dengler
    Jackie Dengler
    21
    Nov 6, 2020
    [​IMG] Help me by reading my post on axes tomohawk hatchet forum please by Jackie Dengler
Share This Page
