1. Week 43of the BladeForums.com Year of Giveaways is live! Enter to win a Spyderco C243PBK Edela + Misc Prize Pack
    Click here to enter the drawing for your chance to win a Spyderco Endela + Misc Prize Pack , Bladeforums.com swag or memberships!
    Be sure to read the rules before entering, and help us decide next week's giveaway by hitting the poll in that thread!
    Entries will close at 11:59PM Saturday, Oct 26 ; winners will be drawn on Sunday @ 5pm on our Youtube Channel: TheRealBladeForums. Bonus prizes will be given during the livestream!
    Questions? Comments? Post in the discussion thread here
Belt tracking problem
Discussion in 'Shop Talk - BladeSmith Questions and Answers' started by Bristol Bear, Mar 24, 2019.
  1. Bristol Bear
    Bristol Bear
    7
    Dec 13, 2018
    hi can anyone help I am building a newer grinder but after completion when I put a belt on all the belt wants to do is track to the left , I have checked all wheels are aligned near on perfect also I have tried a different belt but no matter what I do it just tracks left
    I am stuck for ideas so I have turned to any of you guys for help please.
  2. john april
    john april KnifeMaker / Craftsman / Service Provider Knifemaker / Craftsman / Service Provider
    Feb 27, 2006
    does it track to the left when you are not grinding, or just when you grind ? if it moves over when you are grinding, usually that is a sign of the belt not being tight enough.
    115Italian likes this.
  3. Randy3000
    Randy3000
    722
    Jun 3, 2017
    In addition to what john said, i had an issue of too much play in the tracking/tensioning wheel setup. All the wheels were in the same plane, but that one wheel would twist under tension due to the play and it threw off the tracking. I believe this should only happen if, when changing belts, the belt slips off the left side of the wheels (i.e. they are mounted to the grinder with right side of wheel facing grinder).
  4. Bristol Bear
    Bristol Bear
    7
    Dec 13, 2018
    Hi no the belt is tight and I am not even grinding I’m just pull the belt to check before turning on I’m trying to find out how to upload a video to show it happing
  5. Ken H>
    Ken H>
    Dec 31, 2011
    You really need to upload a photo using one of the free imaging hosting sites. Personally I prefer https://imgbb.com/ but there are other sites available - ANYTHING other than photobucket!!
    Your photo needs to show the type of tracking system you've got and how it's adjusted.
  6. Natlek
    Natlek
    Jun 9, 2015
    If they are near perfect you will have no tracking problem .Check them again ,this time in ALL direction .Wheels are only moving part on belt grinder ....so ;)
  7. Bristol Bear
    Bristol Bear
    7
    Dec 13, 2018
    Imgbb says my video file is to big ? To upload any ideas
  8. Rhinoknives1
    Rhinoknives1 KnifeMaker / Craftsman / Service Provider Knifemaker / Craftsman / Service Provider
    Jul 1, 2013
    Get a image resizer, they are a free app and reduce to about 70% of original. That will do the trick most of the time
  9. Bristol Bear
    Bristol Bear
    7
    Dec 13, 2018
    [​IMG]Hi not sure because I’m using an iPad but I can’t imgbb does not recognise the video format how difficult is this
    Thanks for you help I can’t workout how to upload a video file
  10. Spalted
    Spalted My name is Britt Askew I like making knives Knifemaker / Craftsman / Service Provider
    899
    Dec 9, 2010
    But photobucket says pictures are proudly hosted on photobucket ? :p:poop:
    irfanview is easy to use
  11. Stacy E. Apelt - Bladesmith
    Stacy E. Apelt - Bladesmith ilmarinen - MODERATOR Moderator Knifemaker / Craftsman / Service Provider
    Aug 20, 2004
    Several suggestions:
    Checking by hand rotation isn't going to tell you what seeing it running will. Try and set the tracking manually, then turn the grinder on and adjust while running.
    Rigidity is one of the biggest factors with belts constantly tracking left. If the tool arm or other arms have any flex at all, the belt moves left. Is you tool arm solid or square tubing?
    Wheels align in three axes. Check that they are in alignment from front to back with a good straightedge. Place the edge on the centerline of the contact wheel and the drive wheel. They should touch both front and rear on both wheels. The tracking wheel should be similarly aligned. Then check that all are the same along the shaft axes vertically. Hold the straight edge vertical along the centerline of both wheels and see if either has a cant.
    Check that the tracking arm does not have flex. People forget that the tracking arm needs to be just as solid as the tool arm. It also needs a strong tension spring. It is tighter than one would think if they aren't used to grinders. Adjustable tension is a plus.
    Is the motor bolted to the frame C-face, or a shaft and pulleys. Make sure that there are no loose bolts.
    Try dialing your tracking to the right all the way and see if the issue reverses.
  12. Spalted
    899
    Dec 9, 2010
    Could you post the video to youtube ? then you could just give the youtube link
  13. Bristol Bear
    Bristol Bear
    7
    Dec 13, 2018
    [​IMG] Hope this works
  14. rjedoaks
    rjedoaks Gold Member Gold Member
    217
    Sep 15, 2009
    Your tracking mechanism looks like it needs to be moved outboard some. Try a few washers at a time.
  15. Ken H>
    Ken H>
    Dec 31, 2011
    I don't see how the tracking system works - is the tracking wheel just mounted to that thin (looks <1/4") metal strip? Move the camera around a bit showing the tracking system from different angles and how you adjust it. Make the video at least 30 seconds, better a minute or so long. You're right, not time to start grinder yet - need to get it tracking when turning by hand as you are. Once you get it tracking by hand, then you can run grinder and do the final adjustment.
  16. Spalted
    899
    Dec 9, 2010
    Yea what the tracking wheel is mounted to looks way to flimsy. Question- you said "I have checked all wheels are aligned near on perfect" - how did you check for that? I stopped the video at 15 seconds and the tracking wheel is not even close to being lined up correctly. How do you adjust tracking? the tracking wheel needs to tilt back and fourth , looks like tracking wheel needs to be tilted so the top goes left and the bottom moves right
  17. Spalted
    899
    Dec 9, 2010
    Also I can easily make my belt move to the left like that if I move my tracking adjuster , then I could turn it the other way and make the belt go off of the other side. Trick is to find the sweet spot
  18. Natlek
    Natlek
    Jun 9, 2015
    Judging by what I see at the end of this clip , you need more tension on belt .Tension changed tracking on belt grinders , different tension different tracking . ...And don t pull belt by hand when test , you don t pull straight down you pull on side to . Try to turn belt with one wheel .....
  19. john april
    Feb 27, 2006
    the tracking wheel, as seen/viewed in the video angle, needs to move downward to the right. in the video it is too high to the left, and that is why the belt i moving to the left.
  20. john april
    Feb 27, 2006
    at 0:12 in the video i can see the belt is way too loose because you should not be able to move it like that with a finger. the belt should be tight enough that the unsupported edge vibrates like a guitar string when you puck it.
    Natlek likes this.
Share This Page
