1. Week 47 of the BladeForums.com Year of Giveaways is live! Enter to win a Kizer Knives 1028A1 Dirk Pinkerton Lancer
    Click here to enter the drawing for your chance to win a Kizer Knives 1028A1 Dirk Pinkerton Lancer + Misc Prize Pack , Bladeforums.com swag or memberships! Be sure to read the rules before entering, and help us decide next week's giveaway by hitting the poll in that thread!
    Entries will close at 11:59PM Saturday, Nov 23 ; winners will be drawn on Sunday @ 5pm on our Youtube Channel: TheRealBladeForums. Bonus prizes will be given during the livestream!
    Questions? Comments? Post in the discussion thread here
  2. Esav Benyamin has passed. Please pay your respects here
building a gas forge
Discussion in 'Hammer & Tongs' started by bill may, Apr 12, 2015.
  1. bill may
    bill may
    70
    Jul 30, 2014
    I am looking for some forge building info like gas burner to forge size ratio. I bought a small gas forge that I love but it is limiting on blade size and to my dismay
    I discovered that borax really eats up it's lining. is their material that doesn't do this or is a upright forge the only solution?
    so if any one has any suggestions or links I would greatly appreciate them.
  2. BareKnuckles
    BareKnuckles
    38
    Mar 25, 2015
    There is a ton of info in the stickies in the "Shop Talk - Bladesmith Questions & Answers" sub forum, plus check out the thread "tank forge" in Shop Talk... It has discussion about the forge I'm currently building, and Stacy has the links to the relevant stickies in there as well.
  3. Chris Meyer
    Chris Meyer
    Aug 15, 2005
    Bill, I've noticed that some of the guys switched to Kerosene for their flux. Apparently, it works well and doesn't damage the forge lining. If you Google "Kerosene Flux" you will find a bunch of info. I believe there are some videos too.
  4. Stacy E. Apelt - Bladesmith
    Stacy E. Apelt - Bladesmith ilmarinen - MODERATOR Moderator Knifemaker / Craftsman / Service Provider
    Aug 20, 2004
    On a welding forge, the floor should be a highly flux resistant material, like bubble alumina.
    This search engine will get you dozens of threads with great info (as well as the info in the stickies).
    https://cse.google.com/cse/home?cx=011197018607028182644:qfobr3dlcra
    Just a question for clarification - Are you welding up damascus in your current small forge?
    Some basic info:
    Two layers of 1" Hi-Z inswool, or one 2" layer of regular inswool, are best for a welding forge ( or any forge). The Hi-Z wool is better if you are working at welding temps.
    A 1/4-3/8" layer of Satanite ( over the inswool) with a final coating of ITC-100 will give great performance and long life. Fire and cure the satanite before applying and curing the ITC-100.
    In any welding forge, have a floor that is either replaceable ( kiln shelving), or made from a flux resistant material like Bubble Alumina.
    High Temp Tools is the place for all your forge building stuff. They have everything from wool to ITC-100 - www.hightemptools.com
    Insboard makes great forge ends and floor material.
    Make it big enough, but not excessively. A 10"X16" pipe makes a great forge. The final chamber will be about 6"X14"
    A vertical forge is really good for welding damascus. Put 2" of kitty litter in the bottom to catch the flux.
  5. bill may
    bill may
    70
    Jul 30, 2014
    thanks for info everyone and Stacy thanks for the links and I have done some Damascus but I just got it.
    it has a 2 1/2" by 11" chamber it limits me on my billet size but other than that I'm happy with the job it dose.
  6. ndoghouse
    ndoghouse Gold Member Gold Member
    Aug 26, 2010
    Im building a tank forge as well and was curious is there any downfall to using pearlite and sodium silicate for the bulk of the insulation material. There are many people doing this and that was my plan but it seems most here use other commercially available refractory materials. I Have already built my burners and tested them and can get them to work with little pressure to full pressure. I used iron pipe reducers for the nozzles but machined the inside threads out to 12ยบ taper to smooth out the flow. I would like to be able to get to welding heat with this setup if possible.
    [​IMG]
    The plan was to use this steel milk can. If I use a six inch diameter space inside then ill have two or three inches of material around it for insulation. I was planning to insulate the bottom of the can as well about two inches thick. I may need to whack the neck of the can off eventually if it looks like it will get in the way but it may come in useful for something if I need to put the lid on for some reason?
    [​IMG]
    Basic burner setup with adjustable sleeves for air intake.
    [​IMG]
    The burn pattern with both on full pressure. Seems to work. Next step was to mount 2" flanges to the can so Ill have something to mount the burners to.
    OK Im new to this forging stuff so you guys throw the book at me. I can take it:D
  7. Daniel Fairly Knives
    Daniel Fairly Knives Full Time Knifemaker Moderator Knifemaker / Craftsman / Service Provider
    Jan 9, 2011
    Looking good!
    It's funny, I saw that milk can and thought "those look exactly like the ones on the farm back home" then I saw your location! I'm from the same area.
  8. ndoghouse
    Aug 26, 2010
    Man your work is impeccable! Very impressive pieces. Love your grinder setup as well. Im planning something like that myself soon. Wish we were still neighbors. Id love to watch you work your magic:thumbup:
  9. Daniel Fairly Knives
    Jan 9, 2011
    Hey thanks for the kind words! I'm always moving those grinders around... :D
  10. Atlas Knife Company
    Atlas Knife Company KnifeMaker / Craftsman / Service Provider Knifemaker / Craftsman / Service Provider
    Feb 16, 2010
    To answer the OP's question: According to Ron Reil's website, 400 BTU per cubic inch is recommended for welding. Here is a link to a BTU calculator from his site to determine orifice size, PSI and BTU output. That will allow you to determine what size burner you need for your forge.
    You can also make a stainless foil liner for the bottom of your forge. It seems to work pretty well to protect the bottom of the forge.
    https://www.abana.org/ronreil/BTU_Calculator.xls
  11. Stacy E. Apelt - Bladesmith
    Aug 20, 2004
    dishaverma,
    All the threads you replied to are older threads from 2015. Most of the info you posted is hard to understand due to a language barrier or google translate. Also, much of what you have been posting is not directly related to the thread topic. Please read the date of a thread before posting, and post info that is applicable to the thread.
    Fill out you profile so we know things like your age, where you live, and what you do for a living. That will help us understand your comments better.
Share This Page
