Eye opening quench test results.
Discussion in 'Shop Talk - BladeSmith Questions and Answers' started by Kevin R. Cashen, Sep 23, 2010.
Thread Status:
  1. Kevin R. Cashen
    Kevin R. Cashen
    Sep 9, 2003
    H-K is pretty darned good:thumbup:
  2. Danbo
    Danbo Platinum Member Platinum Member
    Nov 28, 1999
    Whew! When I first read your thread title, I was afraid you had used my L6 blade as a test and had it explode into a bazillion pieces when quenched! ;):p
  3. Sam Salvati
    Sam Salvati
    Aug 6, 2007
    Then there's the movie!
  4. DaveMartell
    DaveMartell
    235
    Apr 22, 2010
    Thanks for sharing your data Kevin. :thumbup:
  5. Nebulae
    Nebulae
    Aug 24, 2009
    that's really cool. Surprising to see such a huge difference thanks for all you do keeping everybody curious
  6. sunshadow
    sunshadow
    Oct 2, 2006
    Ahh, but how about the bitter bite of bainite?:D 1095 was a good year for that.
    (running and ducking the broadsword swings)
    -Page
  7. Nebulae
    Nebulae
    Aug 24, 2009
    Hey kevin I know this is off topic but could you look at this? Photo of broken steel
    there is a picture in there that I think (hope) is worth your time:eek:
  8. Mace
    Mace
    Apr 8, 2003
    SCIENCE!:D
    So, just out of curiosity...would this test oil be good for something else...say 0-1?
    Mace
  9. Mike Morehouse
    Mike Morehouse
    473
    Jun 27, 2009
    Kevin, what kind of oil is used during the austempering process? Is austempering an acceptable practice when hardening a sword? I have seen some blacksmiths austemper but I do not think they knew what they were actually doing.
  10. Stacy E. Apelt - Bladesmith
    Stacy E. Apelt - Bladesmith ilmarinen - MODERATOR Moderator Knifemaker / Craftsman / Service Provider
    Aug 20, 2004
    Yes, I forgot how bainite can leave a bitter taste in one's mouth.
  11. Kevin R. Cashen
    Kevin R. Cashen
    Sep 9, 2003
    Nope, it survived despite my best efforts, I will assume you will pick it up at Ricks next month.
  12. Kevin R. Cashen
    Kevin R. Cashen
    Sep 9, 2003
    It is very hard to tell from just pictures and fracture analysis is an entire complex field of science unto itself so any number of things could be going on there. The lumpy fracture surface is as much an effect of the directed forces caused by your scoring cut, you will notice who closely it follows the shape of your cut mark. If the scoring cut was there before the HT it would be even more interesting with what it tells us about how such factors can steer transformations within the HT itself. One will often get a slightly different look on the tensile side versus the compression side, and this is very much so when there are dual phases. Decarb will always leave a thin line of deformation at the very edge due to a different and more plastic mode of fracture. Pearlite and decarb can illustrate the differences in slow tensile loads and rapid impact loads and let us see the two forms of toughness more clearly. A rather soft steel will fail in a ductile mode and stretch via slip before shear forces get the best of it, but the same piece of steel will fail as if it where much harder, or even brittle, if subjected to sudden loading, due to the fact that it is loaded faster than the ductile processes can occur, thus no accommodation via slip and instead brittle type fracture. When I want to assess fractured ends I always prefer to break it with impact versus bending so that I can get a cleaner look at the surfaces from cleavage fracture without the confusion that the shear based fractures cause.
    This, by they way is the cause of much confusion among many makers who aren’t aware of these processes, causing them to erroneously claim a different grain structure for the edge vs. the spine when all they are really seeing a different mode of fracture from a pearlitic spine.
  13. Kevin R. Cashen
    Kevin R. Cashen
    Sep 9, 2003
    Mace, any good medium speed oil, heck this prototype oil would probably have worked well for O-1. Houghton type “G”, Houghto-quench 3430, or Park Metallurgical AAA if you can get it, are all good examples of oils well suited for O1, L6, 5160, 52100 etc…
  14. Kevin R. Cashen
    Kevin R. Cashen
    Sep 9, 2003
    Austempering is greatly misunderstood by many and very often they only think they are achieving the desired results. To properly austemper one MUST make lower bainite as upper bainite is worse than just having pearlite. Lower bainite is however much more difficult to make than its high temp brother. Upper bainite can happen in minutes, but the lower the hold temperature the longer the time required to make the stuff. Lower bainite occurs in the lower temps before Ms (600F and less) so it takes longer and longer (hours not minutes) depending on how strong you want it. This requires a quenching medium capable of pulling the heat out fast enough to avoid both pearlite and upper bainite while still being able to hold the quenching temp above 450F, which is no simple thing. One could also see how some steel would really complicate matters as well due to their ability to quickly make pearlite.
    Because of this austempering is best done with martempering oils designed specifically to work at high temperatures, or molten salts. Although many makers feel they are doing fine with heating other oils up and quenching into them, what they are actually getting is a mix of pearlite, upper bainite, perhaps some lower bainite and martensite that converted when they finally went to room temp (at least what converted and did not hang around as retained austenite). So by doing goofy things in an attempt at making bainite without the proper process one can perhaps get a horrible mix of virtually every phase commonly encountered, great for metallography samples, terrible for a blade.
    I like this! It is especially true in my case;).
  15. Rick Marchand
    Rick Marchand Donkey on the Edge Moderator
    Jan 6, 2005
    Kevin... would a 400X digital USB microscope be of any use to a beginner in examining and trying to read grain structures? I recently picked one up on the interwebz.
    Rick
  16. Kevin R. Cashen
    Kevin R. Cashen
    Sep 9, 2003
    Rick, the problem is that fractured grain inspection is nothing like metallographic grain inspection. Fractured grain is very bumpy as it reveals the 3-dimensional outer surfaces of the grains, this makes really high magnification useless due to the depth of field issues, 50X to 100X is the most you could hope for and 100X is already only giving you limited depth.
    With metallographic inspection the grains, along with the sample, are cross sectioned and you get a completely flat plain that allows more accurate grain size determination as well as magnifications of 1000X an even beyond.
    So a good loop or hand held magnifier will be just as good as anything more fancy for fractured grain inspection.
  17. Nebulae
    Nebulae
    Aug 24, 2009
    Thanks Kevin! the reason I scored, and broke it via ductile strain is because I intended to use the two pieces, and I was trying not to get hurt.
  18. Rick Marchand
    Jan 6, 2005
    Damn:grumpy:... I was hoping you would say you've been fooling us this whole time and metallography was as easy as cut, polish, etch and look! Now, you're probably gonna tell me something crazy like O1 isn't the perfect beginner steel.:p
    Does the R. in "Kevin R. Cashen" stand for Rug-puller? I keep experiencing the sensation of falling when I read your posts.:D:thumbup:
    Rick
  19. Matthew Gregory
    Matthew Gregory Chief Executive in charge of Entertainment
    Jan 12, 2005
    I knew I liked Karen. She does a surprisingly good job of hitting you where the bruises don't show in public - but of course, hitting you on the head would certainly be a fruitless endeavor for behavior correction. ;)
    I'll bet most folks approach removing that 2mm worth at the edge doing their final finish grinding. That means their edge is made up of 12 or 15% pearlite, I'm guessing? NICE.
    Of course, maybe you're just not experienced enough to use improper quenchants yet, Kev... don't worry, another 20 years and you'll be able to just make stuff up and be believed, too!
  20. Tai Goo
    Tai Goo Banned BANNED
    Apr 7, 2006
    All this really illustrates, is that quench speeds have an effect on the micro structures of the steel, (definitely something to be aware of but),… nothing more nothing less… nothing new.
    It simply shows that one of the quenching mediums used was faster and one was slower.
Thread Status:
Share This Page
