1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Click here to enter the drawing for your chance to win a Boker Urban Trapper Cocobolo , Bladeforums.com swag or memberships!
    Be sure to read the rules before entering, then help us decide next week's giveaway by hitting the poll in that thread! Entries close at midnight, Saturday June 15!
    Once the entries close, we'll live stream the drawing on Sunday, June 30 at 5PM Eastern. Tune in to our YouTube channel TheRealBladeForums for a chance to win bonus prizes!
    Questions? Comments? Post in the discussion thread here
    Also, previous Live Stream Prize Pack winner, ooitzoo, has chosen to "pay it forward" with his knife that he won and is doing his own giveaway, check it out here: https://www.bladeforums.com/threads/nib-cold-steel-prolite.1663761/
Hemp wrap handle question for lanyard tube
Discussion in 'Hammer & Tongs' started by Vpetrell, Dec 22, 2016.
  1. Vpetrell
    Vpetrell
    272
    Jul 14, 2015
    Question for the more seasoned than myself
    I'm doing another hemp wrap handle here soon and want a lanyard tube on this one.
    My question is, without epoxying the tube in place and wrapping around it, can I drill through the hemp without it splitting? I use system 3 marine grade wood epoxy to seal the hemp with
  2. Rick Marchand
    Rick Marchand Donkey on the Edge Moderator
    Jan 6, 2005
    The hardest part is not having a hole that looks ratty from the drill.
    Drill your tang and backing scales before you wrap. Wrap over the hole and slip a toothpick through the center to mark the hole. Epoxy and let cure. Use a drill or a dremel to open the hole close to size. Here is the important part... Heat a tapered rod(I use a long punch) and "melt" the rest of the hole to size. If you have the rod too hot, you'l burn the hole and ruin the epoxy. Taper one side of your tube, epoxy up and slide it in carefully. Let it cure but not fully harden, then file it down flush. After that I like to run a tapered rod in a drill press at high speed to burnish the inside and give it a bit of a flare.
    [​IMG]
  3. Vpetrell
    Vpetrell
    272
    Jul 14, 2015
    Rick thank you! This is actually the blade that got me thinking. I follow you on instagram and saw this on there.
    I will try this method and keep my fingers crossed i do it correctly the first time!
    Thanks again! Your work is some of my favorite
  4. Vpetrell
    Vpetrell
    272
    Jul 14, 2015
    This was great advice. Got around to getting 2 done in this manner
    Thanks again!
    [​IMG]
Share This Page
