1. Click here to enter the drawing for your chance to win an Ontario Knives Spec Plus SP8 Machete Survival Knife & Ka-Bar Dozier Folding Hunter, , Bladeforums.com swag or memberships!
    Be sure to read the rules before entering, then help us decide next week's giveaway by hitting the poll in that thread! Entries close at midnight, Saturday Sept 7!
    Once the entries close, we'll live stream the drawing on Sunday, Sept 8 at 5PM Eastern. Tune in to our YouTube channel TheRealBladeForums for a chance to win bonus prizes!
    Questions? Comments? Post in the discussion thread here
Knife lube?
Discussion in 'Buck Knives' started by Canvsbk, Apr 23, 2019.
  1. Canvsbk
    Canvsbk Basic Member Basic Member
    112
    Dec 18, 2016
    Was wondering what you guys use for lube on those folders. I run all my guns on Mobile One but it seems a bit “heavy” on my pocket folders. It also attracts a lot of gunk from the pocket but I’m not sure I can get away from that regardless of lube type.
  2. Mo2
    Mo2
    Apr 8, 2016
    Use Teflon if your attracting too much dust.
    I use finish line brand or the stuff that comes with the crk sebenza.
    If you can't disassemble, then Teflon grease is probably not idea.
    If you want a fluid try kpl aka knife pivot lube.
    Also if you use a fluid, less is more. So you may be putting to much mobile1 on. 1 drop of lube is enough for both sides and the detent. Lube spreads around very well. You don't want a lake of lube.
  3. jbmonkey
    jbmonkey Platinum Member Platinum Member
    Jun 9, 2011
    truth be told I really dont. I just keep clean from grit and sand etc. if it gets gritty I wash in hot water and dish type soap. then air compressor blow dry and wd40 to remove water, not for lubrication. then wipe out residual wd40 and go back to using.
    OLd_gUY and Brhowser87 like this.
  4. Brhowser87
    Brhowser87 Basic Member Basic Member
    Aug 3, 2016
    If it can be disassembled after I clean it and b4 I reassemble I put a drop of rem-oil on each side. If it can't I use jb's method but sometimes I flush with lighter fluid.
    jbmonkey likes this.
  5. Canvsbk
    112
    Dec 18, 2016
    I think I’ll give the kpl a try. I’ve seen that mentioned before but never knew what it was. Thanks.
    Mo2 likes this.
  6. BuckShack
    BuckShack Gold Member Gold Member
    Jul 19, 2015
    I use mineral oil on knives I plan to use for food prep, Williamsville Butcherblock Oil to be specific.
    RemOil works well for everything else.
  7. Brhowser87
    Aug 3, 2016
    Do u have any adverse effects from the mineral oil? To much gunk or anything like that? I've seen that mentioned b4 but haven't tried it yet.
  8. afishhunter
    afishhunter
    Oct 21, 2014
    Over the last ... 49 or so years I've used a few drops of either 3 in 1 oil, Hoppy's gun oil, transmission fluid, hydrolic oil, new or (well) used 10-W30, 90 weight gear lube, olive oil, corn oil, vegetable oil, or mineral oil, depending on what I had available to lube the joints on my slipjoints and lockbacks at the time. :)
    Rupestris, kyhunt, gotgoat and 3 others like this.
  9. STDK
    STDK Basic Member Basic Member
    Jul 31, 2006
    I use Mineral oil only on all my knives. I don't like the smell of the other oils.
    redcanoe and PirateSeulb like this.
  10. st8yd
    st8yd Gold Member Gold Member
    Mar 6, 2009
    In 30-40 yrs of carrying a knife in my pocket I've never fussed with it. I got a knife the other day and po had oiled, it was smooth I must say. So ive oiled a couple times since without it gunking up.
    As said, it dont take much and wipe it off completely and i wouldnt even worry if its food safe as there wont be enough to cause any harm.
    afishhunter likes this.
  11. eveled
    eveled Gold Member Gold Member
    Mar 11, 2016
    I keep mineral oil handy in the kitchen for wooden spoons and handles and butcher blocks and cutting boards.
    I sharpen in the kitchen. So it is the natural choice for wooden knife handles and pivots too. Never noticed anything bad.
  12. BuckShack
    Jul 19, 2015
    I haven't noticed any adverse effects. No different than other oils. Like most, I oil, work the blade to work it in and then wipe as much off as possible, including nooks and crannies with a folded tissue. It's amazing to see how much black stuff comes out of there, especially on new knives.
    Brhowser87 likes this.
  13. 110 Dave
    110 Dave Gold Member Gold Member
    May 6, 2004
    yes i agree so much with this!!! and i use mineral oil or water to sharpen if i need a coolant or some thing to keep dust from building..
    rem oil is for guns or gears... as any knife is subject to be used for food
    redcanoe likes this.
  14. jmh33
    jmh33 Gold Member Gold Member
    Mar 16, 2003
    Quick Release..
    John
    Mo2 likes this.
  15. Old Hunter
    Old Hunter Gold Member Gold Member
    Jul 12, 2012
    I use either Coon P by SMKW or Zero-Friction by ProShot (gun cleaning products). Been using both for ten years - no adverse effects on any knives that I have ever noticed. OH
  16. mwberggren
    mwberggren
    19
    Jan 3, 2017
    Froglube Extreme
  17. RevolverGuy
    RevolverGuy
    378
    Aug 19, 2015
    Same oil I use for my guns and fishing reels: Hoppe's #9.
    Also If you're using too much oil use a can of compressed air to dry it out before you pocket it again. All you need are a few drops on pivot areas.
  18. bucklife301
    bucklife301 Gold Member Gold Member
    Nov 3, 2018
    What does the mineral oil do to wood I’ve never tried it. I have soaked wooden handle kitchen knives in olive oil. Does it have the same effect
  19. eveled
    Mar 11, 2016
    Mineral oil is what is recommended for butcher blocks and cutting boards. It’s food safe and won’t turn rancid like olive oil and other food based oils.
    It just soaks in.
    Mo2 and redcanoe like this.
  20. bucklife301
    Nov 3, 2018
    Thanks I didn’t know that I have a block I will try it on . It’s kind of dried out should make it look better right
Share This Page
