Picked up a 55! I like it!
Discussion in 'Buck Knives' started by sharkattacksw, Oct 1, 2020.
  1. sharkattacksw
    sharkattacksw
    594
    Aug 4, 2008
    I picked up a 55 the other day and I’m impressed. The knife seems to be a fantastic pocketknife; a great alternative to my trusty 503.
    I noticed that upon opening and closing the blade, it feels a little “gritty” about the mid-way point. Will that go away with use (opening and closing it a lot)? I put a dab of WD-40 in the pivot area and worked it a bit, but that didn’t help.
    Any ideas on how to smooth this out?
    mnblade and jbmonkey like this.
  2. jbmonkey
    jbmonkey Platinum Member Platinum Member
    Jun 9, 2011
    hot water and soap and a brush will get that polishing compound out if thats it. then wd40 to remove water on pivot and good drying.
    although....seems while back there was a run of 55s that had a nonfunctional issue similar to what you describe. someone posted about it year or more ago and Jeff responded what it was etc. worth a search here to maybe see if its the same thing for yours. course that was when they were still walnut scales....thats been solved long since ebony started.
  3. Jeff of the North
    Jeff of the North Gold Member Gold Member Basic Member
    210
    Feb 22, 2020
    I do what @jbmonkey suggested but I finish up with an oil such as Tri-Flow or something similar. I'll apply a drop or two then cycle the blade a few times, wipe and repeat. Most every knife is very smooth after this process.
    jbmonkey and Lesknife like this.
  4. Lesknife
    Lesknife Platinum Member Platinum Member
    Mar 31, 2018
    I’ve had a few that were a little gritty and stiff. Like jb I wash them in soapy water working the action under water. A rinse with plain water and blow it dry with compressed air. Then a drop of oil on the pivot and back spring and that has always made it smooth and sure. Some might take some cycling to get the action broken in and smoother.
    plb, jbmonkey and Jeff of the North like this.
  5. sharkattacksw
    sharkattacksw
    594
    Aug 4, 2008
    Thanks for the info, guys. I have to admit, I’m a little hesitant to put my knife under the running water of my faucet and scrub it with soap and water. I guess it won’t hurt or cause any rust issues?
    Lesknife likes this.
  6. Old Biker
    Old Biker
    774
    Sep 25, 2016
    Hot water and soap, followed by a thorough drying, and some lite oil worked into the joints, won't hurt a knife, Even one made from carbon steel. Your 55 and most Bucks are made from stainless steel.
    O.B.
    mnblade, sharkattacksw and jbmonkey like this.
  7. Lesknife
    Mar 31, 2018
    The 55 is made with stainless and brass and some limited editions are nickel silver. They won’t rust in the short amount of time it takes to wash, rinse, dry and oil. If you let them soak for several hours the wood might swell and the blade might have some lite surface rust but not in a few or several minutes. The ones with carbon steel like 5160 and 52100 will rust as well as other non stainless/ non coated blades.
    jbmonkey likes this.
  8. 300Bucks
    300Bucks Gold Member Gold Member
    Apr 19, 2005
    To the OP,
    We have heard this issue hundreds of times, we answer it with same answer. Open knife with gritty blade turn on hot water let it get as hot as it will get. Then put some Dawn dish soap in it and work blade under the running water. If you think its fixed. Then blow dry the knife with hair dryer, spray it with WD-40 to displace any remaining water, wipe it down and let the WD disappear. Then very lightly oil pivot. Works 99% of the time.
  9. Makael
    Makael KnifeMaker / Craftsman / Service Provider Knifemaker / Craftsman / Service Provider Platinum Member
    Oct 17, 2015
    Ill send a pic of a 55 that the scales warped bad on the one i cleaned with hot water.
  10. Makael
    Oct 17, 2015
    Forgot I used superglue and pressed together. It did split the wood tho when pressed flat 20201001_161715.jpg 20201001_161656.jpg 20201001_161612.jpg
  11. GPyro
    GPyro Gold Member Gold Member
    Apr 18, 2019
    Hope that don't happen a hundred times.:rolleyes:
    I can believe that could happen to the thin walnut scales on a 55.
    It probably wouldn't happen to a dymondwood scale. (And I've complained about those in the past, but they obviously have some advantages...)
    I'm not sure how hydrophobic ebony is. Tho I would guess the thicker the scale the safer.
    plb likes this.
  12. plb
    plb
    188
    Jun 22, 2013
    If you want to avoid water, try using an air compressor only, with a blow gun. I've had plenty of success smoothing out the action of lockbacks and slipjoints by using a lot of high pressure (120 psi) air. Not only will it penetrate and remove debris from the pivot, it will help remove polishing compound and other grit causing friction between the lock bar and the frame or liners.
    The last thing I like to do is put a drop of Victorinox Multi Tool Oil (which is actually more like a thin clear grease) on the blade tang where it rides on the lock bar, making for a buttery smooth open and close.
    GPyro, Lesknife and jbmonkey like this.
  13. Railsplitter
    Railsplitter Gold Member Gold Member
    Oct 31, 2010
    This stuff works pretty good too. The best thing about it is that it dries in a matter of seconds. You'll need to lubricate after using.
  14. Tjstampa
    Tjstampa Gold Member Gold Member
    345
    Mar 25, 2019
    The 55 is a great knife. I flushed mine out with wd40 and tha took care of the gritty feel.
  15. Hickory n steel
    Hickory n steel Gold Member Gold Member
    Feb 11, 2016
    I use mineral oil on a gritty knife including my 55 when I got it, just put a liberal amount in the pivot and operate it to get the grit flushed out.
  16. jbmonkey
    Jun 9, 2011
    is that the walnut version?.....I ask as I had one i left in my truck for summer or two...forgot about it and the very thin scales warped upwards from the pins due to super high humidity and massive heat here. still functional, but i never used it so i gifted it to a coworker without a knife.
  17. sassafrassdogs
    sassafrassdogs Gold Member Gold Member
    Jul 21, 2016
    I have one of the new Ebony ones for an EDC, I really like it.....
  18. Makael
    Oct 17, 2015
    Yes, walnut.
  19. colin.p
    colin.p
    Feb 4, 2017
    That's what I did with a brand new 110 that had a lot of black gunk in the pivot. It was stiff as ole' hell and wouldn't shut properly without manually pushing it into the blade well.
    I have several containers of machine oil (not sure why) and grabbed one to give the pivot a little oil. Apparently, the applicator hole was bigger than I thought and a lot more oil came out than I was suspecting and gave the 110 a good drenching. Smooth as glass now and the ebony covers are well oiled too.
  20. jbmonkey
    Jun 9, 2011
    careful certain oils will swell wood and others can make it soft. id wipe it all off til dry again if it were mine.
Share This Page
