Sharpening A SAK ...
Discussion in 'Maintenance, Tinkering & Embellishment' started by afishhunter, Apr 23, 2020.
  1. afishhunter
    afishhunter Basic Member Basic Member
    Oct 21, 2014
    Since it will eventually need sharpening, how do you sharpen the SAK saw blade?
  2. Alberta Ed
    Alberta Ed
    Jun 29, 1999
    It will take a while to dull that, but I don't think it's possible to sharpen it.
  3. Tjstampa
    Tjstampa Gold Member Gold Member
    315
    Mar 25, 2019
    Small file?
  4. Bill DeShivs
    Bill DeShivs KnifeMaker / Craftsman / Service Provider Knifemaker / Craftsman / Service Provider
    Jun 6, 2000
    Saws can be sharpened with a separating disc and a rotary tool, if you know what you're doing.
  5. Craig James
    Craig James
    182
    Oct 30, 2018
    SAK saws don’t have a typical outward set to prevent binding that a normal saw does, the profile is similar to a cross cut saw with a taper to the centre on alternative teeth, however they are ground more like a serration than a saw tooth
  6. I hadn't tried it yet. But this method shown in the vid is an interesting take on sharpening these. It might work well enough, as long as the saw isn't allowed to go severely dull. The blade is laid flat to the sharpening media (both a flat diamond file and sandpaper on wood are demo'd here) and the sharpening is just a matter of grinding the flat sides of the saw blade. This method can presumably work because of the lack of outward-set teeth on the blade, as mentioned in the previous post.
    Ace Rimmer and Mr.Wizard like this.
  7. Mr.Wizard
    Mr.Wizard
    Feb 28, 2015
    That's like sharpening the back side of serrations. It should work great if deburring is done right.
  8. Papilio
    Papilio
    55
    Sep 6, 2019
    Interesting question. I asked myself the same. The video from Felix Immler has already been mentioned.
    You could try (I have no experience with that) to use a file or rod to sharpen each tooth.
    Bryan Lynch demonstrates in his Victorinox Swiss Army Knife Camping & Outdoor Survival Guide how to sharpen the saw. He uses a Diamond pen sharpener / rod, something like this one (don't know what exactly he uses): https://www.amazon.com/-/de/dp/B01MT3EREP/ref=sr_1_2?__mk_de_DE=ÅMÅŽÕÑ&dchild=1&keywords=diamond+pen+sharpener&qid=1587824136&sr=8-2
    But you will have to be careful not to round up the teeth.
    Another try could be a triangle rod, like those Spydercos for the Sharpmaker: https://www.knifecenter.com/item/SP204D/spyderco-triangle-sharpmaker-diamond-rods-set-of-2
    They would have the advantage that you could sharpen the whole profile of a tooth.
    But those Spyderco rods are quite expensive. Maybe there are cheaper options? For example such three-square Silifix grinding sticks https://www.fine-tools.com/schleifstab.html They are not that fine. I don't know if this would work.
    A moment ago I tried a EZE LAP Hone & Stone but wasn't satisfied. They seem to be too thick to slide in between the teeth easily.
    Generally spoken you would have to sharpen every single tooth from one side in one direction. And same from the other side.
  9. NortonIndia
    NortonIndia
    16
    Apr 15, 2020
    The saw in my field master is starting to get a bit dull from use. I fully intend to try Felix Immler’s technique of thinning the sides.
  10. NMpops
    NMpops
    775
    Aug 9, 2010
    Several years ago I bought a used Hiker at a flea market and the center portion of the saw was dull. I took it to a professional saw sharpener.He said the teeth were set more like a Rip Saw. He put it is his jig, adjusted the settings and had it like new in ten minutes.
  11. Craig James
    Craig James
    182
    Oct 30, 2018
    Rips are cut perpendicular to the plate, nothing like a SAK saw from what I remember of them, where as cross cuts are at 45
Share This Page
