SPECIAL EDC Fixed Blade - Defense and Survival
Discussion in 'General Knife Discussion' started by BladeAndBBQ, Feb 3, 2021.
  1. BladeAndBBQ
    BladeAndBBQ
    9
    Feb 3, 2021
    Hello knife friends,
    I am relatively new among knife lovers and would like to find out more here and hope that you can help me with your knowledge.
    I'm looking for an EDC knife that best covers the areas of self-defense and survival.
    I would like a knife, like an Amtac Blade Northman, maybe in carbon steel, but all types of steel are interesting.
    The following specifications should be met:
    Price: doesn't matter
    Total length: max. 8,66 Inches
    Blade length: min. 2,35 max. 4,72 Inches
    Blade shape: needlepoint / dagger, sharpened on one side
    Blade material: doesn't matter
    Weight: max. 5 Ounces
    If someone can give helpful tips and information, I would be very happy.
    Thank you and stay alive!
    Kraken82 likes this.
  2. deovolens
    deovolens
    484
    Dec 25, 2004
    [​IMG]
    unwisefool and Shorttime like this.
  3. Shorttime
    Shorttime
    Oct 16, 2011
    Another vote for the Boker/Burnley Cub, the bottom knife in deovolens' picture. It's discontinued though, so you may end up on the auction site.
    The Northman roughly resembles an historic knife called the "Sgian Dubh", which I don't think is any accident. An image search may get you some acceptable alternatives. I know Emerson did a Sgian Dubh pattern, a long ways back. That would be everything you're looking for, quality-wise, but I suspect you will pay dearly for one.
    unwisefool likes this.
  4. Yo Mama
    Yo Mama
    Sep 25, 2011
    Needle point and dagger don't equal a good survival blade.
    While in theory you can self defend with a survival blade, you really would be at a disadvantage having a self defense type blade for survival.
    I'd check out Becker for survival knives designed for the outdoors.
  5. Silvanus
    Silvanus Gold Member Gold Member
    May 17, 2012
    A knife with a needle point/dagger grind isn’t going to be a good survival knife. Those knives are primarily designed for thrusting and don’t generally make good utility blades.
    In response to your question though, something like a Bradford Guardian 4.5 might fit what what you’re looking for
    StoneAndSteel, DocJD, Yo Mama and 2 others like this.
  6. Alberta Ed
    Alberta Ed
    Jun 29, 1999
    A plain, ordinary Mora would fit your specifications just fine.
    Chronovore and Henry Beige like this.
  7. Burke
    Burke Gold Member Gold Member
    Feb 25, 1999
    Watson Magni, RMJ UCAP would be a couple versatile EDC fixed blades.
  8. jstn
    jstn Gold Member Gold Member
    Jun 27, 2012
    Maybe something like the Doublestar Hydra Lite Fighter. Doesn't fit your specs exactly, but was designed for self-defense use and could be flexed into a survival role too. Nitro-V steel, which I like as a tough, easy to sharpen stainless.
  9. Grendelsnap
    Grendelsnap
    48
    Mar 24, 2014
    I've found daggers to be almost useless in the field. Close quarters on the streets of Shanghai? Absolutely.
    For a good general use EDC knife I've always liked Emersons tanto's. They're great at everyday tasks like opening packages, easy to fix if the tip breaks, precise, compact, ext. Emerson makes a really nice fixed blade version of their legendary CQC.
    [​IMG]
    For a field knife I like something with a little heft and a strong point but still easy to carry. TGULB has been filling that role out in the woods lately.
    [​IMG]
    Atomic Inc likes this.
  10. DocJD
    DocJD
    Jan 29, 2016
    EDC , SD , and survival / extreme hard use all call for very different designs .
    To best serve all three , I'd focus on a good general purpose camp / field knife on the sturdy side but not too blade thick .
    Cold Steel Master Hunter in 3V would be my choice .
    You're least likely need will be for fighting , and that type of knife is not very good for most normal uses .
    Master Hunter will work fine as a SD knife if necessary , but I'd look to better weapons than a short fixed blade if you are really at risk .
  11. Arathol
    Arathol Basic Member Basic Member
    Jan 1, 2003
    Maybe something more like this?
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    John A. Larsen and lieferung like this.
  12. jstrange
    jstrange
    Mar 31, 2012
    Look at some of Fred Perrin s work. He has mid tech, custom and models by Spyderco. Many would fit an SD and utility role. Survival would be best left for something more beefy.
    I also like the Griffon m10, they make it in a bayonet grind (SD), but also a flat grind that would serve many tasks well.
    lieferung likes this.
  13. Richard338
    Richard338 Gold Member Gold Member
    May 3, 2005
    CPK DEK1
  14. Chronovore
    Chronovore Basic Member Basic Member
    901
    Aug 29, 2019
    The Mora Companion could probably handle all your needs. The only problem is that the stock sheath is terrible for EDC. Luckily, there is an easy solution. Check out RK Custom Kydex. They make an excellent replacement sheath for the Companion. It's light, minimalist, allows for a full grip on the draw and offers excellent retention. That, the knife, and either a Tek-Lok or soft loops add up to just over fifty bucks.
  15. MtnHawk1
    MtnHawk1 Basic Member Basic Member
    321
    May 22, 2019
    Survival in what kind of environment?
    For me, that would be the most important factor. I doubt if there is any one knife that would work equally well in all environments.
    I carry a ~10" blade knife in the forest for chopping wood as well as other tasks, such as game and food prep. It would also work well as a survival knife there and in every other environment I can imagine that I'd be in. If it comes down to it, I'd rather have a knife that is too big than too small. I consider a knife to be a relatively poor self-defense weapon, but if I had to use the 10" for that I wouldn't feel like I was too disadvantaged.
    DocJD likes this.
Share This Page
