Touchup Scales
Discussion in 'Chris Reeve Knives' started by jephdub, May 29, 2020.
  1. jephdub
    jephdub
    10
    Dec 15, 2019
    I do not have a sand blaster at home and I came across ApostleP suggestion of using sandpaper and rolling over scale to remove undesirable ‘shiny’ parts. FYI I don’t mind snail trails.
    I was hesitant but decided to try it out. I did it a little different then suggested, where I put the 100 grit sandpaper on the scale and using pen end rubbed vigorously on backside of sandpaper, repositioning sandpaper often. Then switched to 180 grit paper.
    I must say this worked out very well and wanted to share my experience. Try at your own discretion.
    Here’s a before and after of a scratched clip I did
    https://imgur.com/a/gX04GF9
    For another DIY, had minor scuffs on blade, using oil and green compound I was able to remove by rubbing for about 1 min with a Qtip
    pxl and Llasi like this.
  2. Peter Hartwig
    Peter Hartwig Gold Member Gold Member
    Feb 29, 2008
    Sounds basically like scotch biting. I find it makes the scales a bit slippery, and you likely will not be able to get the factory to re-blast it latter. It does get rid of snail trails though.
    It is a different look and many like it.
  3. jephdub
    jephdub
    10
    Dec 15, 2019
    pxl and EveryDayTaco like this.
  4. bart1
    bart1 Gold Member Gold Member
    May 24, 2009
    Nice results... good job..
  5. Peter Hartwig
    Feb 29, 2008
    I now understand what you did-good tip
    pxl likes this.
Share This Page
