Warning on PM2 10V
Discussion in 'Spyderco' started by John_0917, Mar 23, 2020.
  1. sndmn11
    sndmn11
    33
    May 1, 2006
    I would do the rest of the scales and then it would be one of a kind tiger stripey. I wouldn't have any shame over the marks and think they look neat and unique. If you bought the thing to use, then take a lesson and use it like it was made for.
    KELAMA and John_0917 like this.
  2. Boxer .45
    Boxer .45 Gold Member Gold Member
    Jan 11, 2015
    I had to send a tan PM3 back to distributor because when I changed my clip orientation the threads on the screws, all three screws, stripped. I wasn't torquing hard either. They did research and said apparently it was a known issue sometimes. I had multiple other PM3s before that.
    John_0917 likes this.
  3. bearfacedkiller
    bearfacedkiller Gold Member Gold Member
    Jan 23, 2014
    I am seeing two levels of operator error. I’m speechless. Wow.
    craytab, KELAMA, buckeyejake and 4 others like this.
  4. Murphjd25
    Murphjd25 Gold Member Gold Member
    Apr 27, 2016
    Yeah I can’t help but just LOL at this debacle. Unbelievable.
  5. AF
    AF Gold Member Gold Member
    Jan 14, 2000
    Wow, minor issue made much worse.
  6. Spydergirl88
    Spydergirl88
    490
    Dec 3, 2015
    Open flame - 1
    G10 - 0
    KELAMA and jux t like this.
  7. ReignChaser
    ReignChaser
    32
    May 26, 2019
    No. No you didn't have to use a torch. That's like saying all you have is a shotgun in your house, so you had to use that to get the screw out. You took a drastic action that was completely wrong because you got frustrated and lost your temper. We've all been there. You needed to relax, walk away, and figure out a better way to fix your problem.
    KELAMA and AF like this.
  8. michaelm466
    michaelm466
    Mar 5, 2009
    No problems switching the screws on my DLC version.
  9. John_0917
    John_0917 Gold Member Gold Member
    Apr 15, 2014
    The black marks mostly all came off with ultra fine sandpaper.
    Oloung1 and skyhorse like this.
  10. John_0917
    Apr 15, 2014
    ok, so let’s follow your suggestion...oh wait there wasn’t one
    Roy Batty, 1Ronin and insta9ves like this.
  11. Murphjd25
    Apr 27, 2016
    ...... LOL
  12. Spydergirl88
    Spydergirl88
    490
    Dec 3, 2015
    Mesothelioma
    KELAMA likes this.
  13. Wharn
    Wharn Gold Member Gold Member
    Feb 1, 2011
    You can call those scales “burnt battle damage brown” now.
    ToxicBot11, KELAMA and steff27 like this.
  14. fonedork
    fonedork Platinum Member Platinum Member
    Jul 7, 2011
    Anger management
    KELAMA likes this.
  15. elkins45
    elkins45
    Jun 17, 2006
  16. elkins45
    elkins45
    Jun 17, 2006
    [​IMG]
    The liners are tapped on the opposite side. Get some longer 2-56 screws from the hardware store.
  17. sharp_edge
    sharp_edge Gold Member Gold Member
    Jul 30, 2015
    Looking at my PM2, the tip of the blade would hit the screw closer to it, so no - this won't work for PM2.
  18. elkins45
    elkins45
    Jun 17, 2006
    Actually it just barely misses. I added the longer screws to my PM2 just for reinforcement and there’s no contact. I’ll post a photo if I can.
  19. elkins45
    elkins45
    Jun 17, 2006
    [​IMG]
    This is my blue PM2 that was just recently returned to the lost. It’s been sharpened a few times so maybe a factory fresh blade might just possibly touch, but you could still add two screws and get pretty good support. I add one of these screws to all of my tip-up knives because it helps lock the two liners together at the end and just generally makes the clip attachment stronger.
    sharp_edge likes this.
  20. dogboye
    dogboye Gold Member Gold Member
    Nov 23, 1999
    ouch....
    I don't spend too much time around here, and when I do, I mostly lurk. I should lurk more. i keep missing cool limited releases.
    Anyway, regarding the issue the OP had: for future reference, if this happens, try this:
    Get a nail. For these size screws, a finishing nail works best, and gets hot faster. You'll also need a pair of pliers, and a source of heat. A Bic lighter is sufficient, but if you have something else, that works, too.
    Heat the nail. If you're patient enough and have a good enough source of heat, get it so hot the tip is starting to glow.
    Quickly stick the tip into the socket of the screw, and hold it there 10 to15 seconds.
    Use the torx and try turning it. If still stuck, repeat the above procedure.
    I used this to get a red-loc tited screw out of ... man, can't remember the name of the maker. [edited to add: it was a Greg Lightfoot folder] But, it took about 4 passes to get the clip screw hot enough to loosen the red loc tite. But it worked. And neither the knife, the screw, nor the torx bit were harmed.
    I've also used this same method to get the front night sight on a Glock removed, after the tritium had faded to the point of being useless.
    If you have a soldering iron, it will go even faster. But, it gets hotter, too, I believe. So still possibly risky.
    4mer_FMF, KELAMA, Oloung1 and 2 others like this.
Share This Page
