What do you think of my grinder stand idea?
Discussion in 'Shop Talk - BladeSmith Questions and Answers' started by FRESH_OUTTA_800AD, Apr 26, 2020.
  1. FRESH_OUTTA_800AD
    FRESH_OUTTA_800AD
    10
    Dec 24, 2019
    Recently finished a pivoting 2x72 using Jeremy Schmidt's plans, and now its currently clamped to the side of my workbench while I decide what it's permanent home is going to look like.
    I have a small garage, '1.5' car width, so space is a premium. Aint no cars parking in my workshop. Decided mobile grinder stand is best so I can shuffle things around when needed.
    I'm considering using 1.5" - 1/8" walled squared tubing, unless that is a dumb idea. Could honestly use some suggestions on tube sizing for something like this.
    Table will have a 1/8" plate on the top surface where the grinder mounts, and the back shelf. The grinder will be mounted to the frame rails through the plate. The bottom plate will be 3/8", mainly to lower the center of gravity
    I also want to be able to have a water bucket partially tucked under in the frame. I'm thinking of using a making a sliding table to allow the bucket to be tucked in/pulled out more easily.
    The VFD will be mounted on the top off to the side via a post mounted to the top plate.
    These pics are the general idea. I need to adjust the leg length to get the grinding height right, and I'll put castors on the bottom. Didn't think the extra effort of sketching the castors up was worth it, you get the idea.
    I want to have some storage internal to the frame to make use of the internal frame space, although I am still thinking about what would make the best use of this space. I'd also probably mount some sort of rack to one side for belt storage.
    Was wondering if anyone had done something like this before, wished they had done something a little bit differently if they had the opportunity, or just some other general input before I head down to the steel store.
    [​IMG]
    [​IMG]
    [​IMG]
  2. Stacy E. Apelt - Bladesmith
    Stacy E. Apelt - Bladesmith ilmarinen - MODERATOR Moderator Knifemaker / Craftsman / Service Provider
    Aug 20, 2004
    Overall, a good idea. I think it would work well as a fixed location stand. Making anything roll is more complicated.
    The welds must be rock solid!
    Make sure width is wide enough for center of gravity balance. With a grinder on the top it might be a bit "tippy" when rolling around.
    I don't understand why the back "shelf" area is dropped below the front. It would be more usable space if it was the same height as the rest of the top.
    I would not extend the legs past the bottom shelf if putting on casters. Use heavy duty casters - straight roll with locks on the front, swivel on the back. Bolt or weld the caster plates to the bottom shelf plate.
    DustinY and RayseM like this.
  3. FRESH_OUTTA_800AD
    FRESH_OUTTA_800AD
    10
    Dec 24, 2019
    Hi Stacy
    The concern I have with a fixed base is that I will likely at some point have to shuffle things around, and I expect the combined weight of this sucker to be kinda heavy. I think it would be less likely to tip if I don't have to rock it back and forth to move it around. Probably tear up my floor less this way too. Will do some practice welds on some 1/8" scrap to get the settings dialed in. Bit thinner than the 3/8" I've been working with lately.. :)
    The back shelf is dropped because with this grinder design the motor dips below the top surface plate by 6-7". I've seen this solved in other ways, like just making the grinder base legs taller to give the motor clearance, however I think with the base will be stiffer with shorter feet.
    I was also thinking of ending the legs at the lower frame so I get more room above the bottom plate. I'll mount the castors to the outer corner pieces.
  4. Hubert S.
    Hubert S.
    258
    Dec 14, 2019
    I would recommend retractable casters and leveling feet to give it more stability. Hockey pucks are cheap and make great leveling feet. They can be drilled easily with Forstner bits.
    Here is a video showing DIY retractable casters, maybe you could do something similar to that. The fellow has a whole series on different caster solutions, the video is just part one.
    DustinY likes this.
  5. FRESH_OUTTA_800AD
    FRESH_OUTTA_800AD
    10
    Dec 24, 2019
    Oh yeah that's a pretty good idea. I could use those on several things to be honest. I think I'll stick with locking casters for now. If I find that to be annoying/I can try adding weight to the bottom shelf.
  6. mike-E
    mike-E
    394
    Mar 2, 2013
    I think the cart/stand is too tall. Start by measuring from the ground up to your elbows. That measurement is the height you want the center of your tool arm pocket(platen receiver). Don't forget to account for the added height of the casters.
  7. Kevin McGovern
    Kevin McGovern
    Jul 31, 2015
    My grinder is about 2x heavier and it's mounted on a harbor freight base. It's like $30. Totally solid.
    Fred.Rowe likes this.
  8. golfer1
    golfer1
    384
    Nov 24, 2016
    Might be neat if the height was adjustable so you could grind from other positions
  9. Fred.Rowe
    Fred.Rowe Dealer / Materials Provider Dealer / Materials Provider
    May 2, 2004
    I use that base and you are correct, you can load the stand and it is stable and solid. The price is right also.
  10. Rhinoknives1
    Rhinoknives1 KnifeMaker / Craftsman / Service Provider Knifemaker / Craftsman / Service Provider
    Jul 1, 2013
    Weight cuts down on vibration which can be tiring & louder, if you like to grind a stack of blades or taper all of the tangs. I find it makes a difference ..I also have thicker top pieces on my two grinders . One is 1/2” plywood & the other 1/2” poly like they cut food on in commercial kitchen. Also smooths things out.
  11. WhitleyStu
    WhitleyStu Keep'em scary sharp!!! Knifemaker / Craftsman / Service Provider
    752
    Dec 8, 2006
    I've found that a rectangular or square water container under my 2x72 catches more than a round one. Just an observation...
  12. FRESH_OUTTA_800AD
    FRESH_OUTTA_800AD
    10
    Dec 24, 2019
    Well hot damn, if that’s a viable option it would be a helleva lot cheaper than building my own. I’ll check it out. Might be a good interim solution
    Square bucket is also a good thought.
  13. Ken H>
    Ken H>
    Dec 31, 2011
    If you're not moving very often you might use a fixed stand, then a hand truck/dolly to move it around when needed. That's what I do and it works pretty good. Just have to be careful about the top heavy issue.
  14. Kevin McGovern
    Kevin McGovern
    Jul 31, 2015
    i think you can also get a wheel base that you can retract the wheels when it's stationary.
  15. Kevin McGovern
    Kevin McGovern
    Jul 31, 2015
    Forgot to mention! My grinder weighs about 130#. If you grinder is considerably lighter, it may not be solid and move when you push into it.
  16. FRESH_OUTTA_800AD
    FRESH_OUTTA_800AD
    10
    Dec 24, 2019
Share This Page
